My Xperia XZs Dual-SIM received Android 8.0 update and installed few days ago. Just noticed that the battery icon in status bar (the one you drag down) keeps the same all the time as a fully charged one. The battery icon dosent have percentage with it and will not change at all no matter when charging or in using. The one at top works fine though both when you dragged down the status menu or not.
I just want to know if anyone had experienced the same issue or, if that's really a bug since the battery icon in 7.1.1 used to have percentage at its bottom and animation just the same as the one at the top sits between time and signal strength.
And confirmation on bug others mentioned that traffic indicator (those 2 arrows) on the left side of the signal icon will push away any icon on its left when activate which is kind of annoying. Hope the next update will fix this.
