Solved! Go to Solution.
Difficult for me to say as mine is rooted and a lot of system apps are either removed or frozen however I currently use 4.4.4 version 14.4.A.0.108, I did try LP but found it unusable
@David-Yaoming The different firmwares and been stable depends on your definition of stable - I have all firmwares for the C6833 as it's the device I use - So if you want JB, KK or LP then then I have them but they are the UK releases
Have you considered creating your own firmware for manual flashing which you would need to do - See here for details and tools
