This phone is a bit fragile. I had it in my back pocket. Took a seat and here is the result.
Does anybody know where I can get a replacement for the back glass? I love the phone but I really want it fixed.
Edit:
Just got off the phone with Sony Support, since I am in the USA, sony does not offer any service on this phone. The glass that is used, is sharp and will cut. This is definitely not a kid friendly phone and most definitely not to be used as any everyday casual phone. If you forget it in your back pocket when you sit it will shatter the back glass.
This is the second sony phone that is destroyed in my pocket in 3 months. I guess I need to move back to HTC.
Solved! Go to Solution.
Glass will crack, metal will bent if you seat on it, that's normal, more so if the phone's screen its that big as the Xperia Z5 Premium, I understand your frustration but if you bought the phone online perhaps at amazon or ebay you should check the warranty options and/or how to service the phone.
You need a bit more context, the phone it's not available here in the USA, therefore there aren't any spare parts, also, the warranty its only available in the country were the phone its bought, otherwise its consider grey market.
