Solved! Go to Solution.
It is a two step button, first is very light and it works as a camera focus button,but you should feel it clicks in a half way, than you press harder and it takes photo just like a real compact cameras do. If you don't feel any pressing degree it might be faulty, it's just a silicone stripe with plastic buttons so it could be badly installed in factory.
Last time, just to be sure, try to start the phone in service mode (restart and when sony logo appears press volume down till it fully starts and you see grey text on main screen "safe mode" if then it will work - reinstall android with sony companion, and if system repair won't do any changes consult the phone in sony centre or the shop where it was bought.
As it works in other modes than SuperAuto I would suggest to clear cache and Data of the camera App in settings, aplications, ALL.
Other thing you need to test it in manual mode, timeshift burst and videos do not actually use the half-button focus, but react for full press.
Try to clear data nad cache in settings and then restart phone, will see if that will help
Ohh.. It worked! Still the front cam
Yes, firstly, when you press on that cam button, a focus frame adjusts itself on the self (which is in the color of white) when it has focused it becomes blue..then press down harder, you will feel it being pressed 2nd time as well.. and voila!
A picture is captured..
P.S the colors of the frame don't matter much but they can be used to indicate that now is the time to press down harder.
Surely tell if this helps.. hopefully it will.. worked for me, i have Experia C ..
