Google Play Services crash after upgrade to 28.0.A.8.266
AdyInbetween
Hi There,
I've just upgrade my Z3+ Dual to 28.0.A.8.266. But after the upgrading finished, my phone keep showing "unfortunately google play services has stopped". The notification keep showing and I can't use several apps like google maps and google play store.
I have cleared the cache and cleared data of Google Play Services apps but the error keep happens.
What do i have to do to solve this problem? or can i just go back to earlier system software ?
AdyInbetween
The problem solved after i uninstalled Google Play Services and installed it again
Uliwooly
@AdyInbetween
try something basic first, restart the phone
if that doesn't work then boot on >>> safe mode for few hours and if you don't experience the same issue then it's a third party acting up
AdyInbetween
Uliwooly
Excellent
