Z5 dual low sound volume and vibration power
RaymondCheng
Is there any setting to increase ring volume or vibration power?
profile.country.RO.title
_alexdon_
You cannot change vibration intensity. Perhaps there are some 3rd party apps that let you customize it however.
Related to volume, you can raise the volume using the side buttons.
alexdon
_alexdon_
alexdon
