Help! Where's my favourite Z3 Live Wallpaper?! ๐Ÿ˜ฎ
TINA66
Does anyone know how or if it's possible for me to get back one of Sonys live wallpapers which was stopped with the Lollipop update - it was like a kind of smoke effect with different colour choices for the background โ˜บ
Rickard
Master
I think you are referring to the live wallpaper "Magic smoke".
I believe this wallpaper is standard for Android but it was removed with Android 5.0. But there are some similar wallpapers on Google Play if you search for magic smoke.
Phy
Legend
Legend
Could you be more specific?
1. Long press on the screen
2. Themes
3. Live Wallpaper
4. Xperia
5. Settings
TINA66
I know how to access the ones that are still available. I want to get back one of the wallpapers that SONY themselves discontinued with the Lollipop upgrade....
Rickard
Master
