How to delete smart cover app from Xperia Z3?
Brezza
I kindly ask you to respond how to delete smart cover app from XperiaZ3? It is a real problem - first of all it is even can't be found within installed apps... Do you have any solution? Thank you very much in advance.
23 REPLIES 23
Thommo
Genius
Open Settings then Apps and swipe to all then locate and open the app and then tap uninstall
Brezza
Thanks, I found this app in all, but it can't be stopped - when I press stop - it notifies that forced closing affects its functionality, and when I accept - nothing happens. And there is no option to uninstall.
Thommo
Genius
What about disable as it appears that this is a system app which would require root privileges to uninstall
Brezza
I see, but I can't even to stop it, I press stop, but it doesn't work..
Thommo
Genius
Do you not have a Disable box? If not then I fear that stopping this feature is not possible
Brezza
Actually, I don't have. How could I get it?
Thommo
Genius
You can't - You either have this option on the app or not
Jake-SonyXperia
Champion
Hi Brezza,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you able to provide a screenshot of what you see when you select the application?
Sorry for this inconvenience.
Brezza
after I press OK nothing occurs..
