How to setup different operating modes
charlest
Hi, I was wondering whether there's a way to setup different operating modes.
For example,
At home, I would like to set "wifi on, stamina on, mobile data off".
Away from home, I would like to set "wifi off, stamina off, mobile data on".
I've been using widgets icons & they're great; as shown below.
However, is there a way to setup something (by software or hardware) such that I could tap once for each operating mode?
Tags (1)
Uliwooly
You can use a smarttag
http://www.sonymobile.com/us/products/accessories/xperia-smarttags/
also keep in mind that if you are on wifi your data will be off.
Uliwooly
pessar
You can use the app Smart connect. Within smart connect you can define conditions (like disconnecting from your home wifi) to initialize a set of actions (disabling wifi, etc.). The only manual action that you still need to do is to enable wifi when you get home.
charlest
Thanks for your reply.
