- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I want to buy a ,memory card for my xperia zr. The site shows that the phone supports a 32gb external memory. But im worried if it will make my phone slow.
Also, i wanted to know which class (class 4, class 10) memory card i should buy?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I saw the video. It states that it is preferred to buy the similar class of sd card for the corresponding device. So can u tell me which class does the xperia ZR support?
The class qualify the speed of tha card, compatibilitty is not issue here.
So higher is the class fastest is the card (but take in considerations the read and write speeds which may vary on different models). Try to find speed comparison tests in reviews to help you to choose the optimal card for your needs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Before you buy any SD card, check this out
http://pocketnow.com/2012/05/28/android-guy-weekly-everything-you-need-to-know-about-sd-cards
make sure to watch the video
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi!
Also it does not solve my query on which is the maximum size of sd card that the xperia can support without lag. can u help me with that as well/??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Ankit_Golatkar wrote:The site shows that the phone supports a 32gb external memory.
Since latest firmware update cards up to 64Gb are supported, look here: http://www.sonymobile.com/global-en/software/phones/xperia-z/
"Support for bigger (64GB) SD card so that you can store even more on your Xperiaâ„¢"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
But if my phone supports a class 4 sd card, it becomes pointless for me to buy a class 10 sd card. hence i asked till which class does the xperia zr support?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Ankit_Golatkar wrote:But if my phone supports a class 4 sd card, it becomes pointless for me to buy a class 10 sd card. hence i asked till which class does the xperia zr support?
Sd card *class* is only related to speed performance rating of the card not the phone.
There is no compatibility issue here.
Saying "supports a class 4 sd card" doen't make ant sense. Any phone supports virtually any card class.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
well what mathers is what you wanna do if you plan to record 1080P videos and so on then class 10 is recommended for best speed while class 4 is for less speed and usage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I used my older 16 GB Class 10 SDHC card and it works very well. No issues so far.
