Hi, Trying to add a "messages" widget to my lockscreen but one isn't available. The only widgets available to be added are: Calendar, Digital clock, Email, Gmail, Google Now, Google+ posts, and TrackID. Isn't there supposed to be a messages widget as well so I can see new messages from the lockscreen?
Solved! Go to Solution.
I have not seen a messages option available for a lock screen widget on the Xperia Z1, I have checked a few units here to confirm.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
I can second what Sam said, you will need a third party lock screen app to do so.
I would have thought that being able to view your messages without unlocking your phone would defeat the object of having a lock screen??
