my xpera z3 d6633 not power on
mohammedsameer
hello evryone
i press power button + up and down volume button my z3 is 4 vibrations and shout down to reset my z3
now i cant make on i press 3 button agen not working please help me
regards
Tags (1)
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
_alexdon_
alexdon
jaguar81979
i have a sony xperia z3 d6633 , it had a software problem and i needed to do a hard factory reset, i pressed the voleum up+ down and power button, the phone vibrated a few times and it didnt turn on. i tried to power it on but it never worked i tried connecting it to the computer it was not recognized and still didnt power on. the phone is completely dead even though it was charged above 80% i looked online and there are a some people who had the same issue but no one has a solution. does any one have a way to power the **bleep** thing on?
