proximity sensor issue
spiralz
My phones screen won't come back on after making a call seems to be a proximity sensor fault.
As soon as I press the call button the screen goes blank even if it's not against my ear. If I press the power button it will come back on and then stay on even if I then press it to my ear.
Very annoying to be honest and I can't find a setting for it
Tags (1)
65 REPLIES 65
Shanky_0cr
No it's just the usual screen guard film, nothing else.
Also I don't even keep the phone near my ear, for the proximity sensor to just lock the phone during a call. Like even when the phone is in my palm away from my ear and I hit the green call button, boom display is off.
Uliwooly
Is it the preloaded/pre-installed ASF (anti shatter film) or is it a secondary scratch resistant film? If the later try to lift the top and make a call, see if the problem persist
Shanky_0cr
It is a secondary scratch resistant film, and I removed the entire film and tried but yet I'm seeign this issue.
Uliwooly
Test your phone with
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester
it will be wise to repair your phone with
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
дикая
Камила ...
Здравствуйте! Помогите, купила эксперию z, пользуюсь месяц, в целом всем довольна, но есть, вернее появилось одно Но. При наборе вызова экран гаснет и даже после окончания разговора невозможно включить экран. И даже потом минуты 3-4 не включается. Что это? Помогите!!!! очень прошу откликнуться. Может прошить ?
Sam
Legend
Legend
Please post in English so that we may assist further.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
shankar_0cr
I fixed it..............
I un-installed an app which I installed called the DU battery saver and after that I'm not seeing any issues.
Thanks all of you for your support!!!!!!!!!!!!!!!!!!!!
haqiqihans
The caller ID of my Xperia Z1 sometimes ( twice a day) blacks out or disappears leaving nothing but a black screen after making a call. It seems to be a bug with proximity sensor. The screen goes blank as soon as I dial any number. And sometimes it happens even if it's not against my ear. This behavior sometimes come back to normal, and sometimes does not change even after pressing the power button.
I would be highly obliged if any body could help me.
Thanks in advance.
abbaskhan
Thanks a lot
Hi
 this is baas  from Amsterdam,, after changing digitalis I got problem with sensor ,, when even I called screen goes black and wont turn on again ,, so this helps i did update and it works perfect ,,, i did try many app to disable the sensor and even , was allot time to search how to disable sensor in Sony experience j ,,, like Samsung have that option
 but thanks allot it works fine
 thanks thanks thanks
peterwin1
I take along a crock pot wherever I go. I just place my phone inside with the cover on for a few seconds to kill the signal and restore the screen LOL
