Service state -Voice: Radio off — Data: Radio off
Mjmdroid
Was at the beach today while using my phone I lost signal but was thinking it's because of poor network , since I lost signal at the beach I could'nt get it back and it's now 7 hours , and I now realized that it's not charging anymore ; I'm now desparate because I don't know what to do ? I did Factory reset twice but that didn't solve it RADIO is still off for both cellular and data
Any solution before I sent it to sony?
Tags (1)
19 REPLIES 19
Mjmdroid
I did the same thing but nothing happens just like you, just give it some days and it'll comes back alone
marcel45
Oh, okay. There's a another code *#*#7378423#*#* where you have more Settings. I recommed you to reset you phone after saving important Data with the PCC (PC Companion). Then after saving and resetting, the antenna and hardware will reboot again.
Keep us updated. Slightly_smiling_Face
Chamchoun
I tried *#*#7378423#*#*, and Clicked on Service Settings, and I see that the network Mode is grey so i cant click on it. then I triedService Tests, adn clicked on Antenna RX diversity, and all tests failed.
marcel45
Oh okay, so I think you still have Android 5.0.2. In anyway, did you reset the phone?
Chamchoun
I just reset and the issue is not resolved.
marcel45
That is not good to hear. In anyway, contact your coustomer local care of Sony. Your Xperia still should have a warranty.
Jest6
I am having the exact same issue. Xperia Z3 D6603 was in my car while I was at work (February in England so great not an issue). Checked my phone at lunch and had no signal. Thought it was the network so checked again once I got home. Still no signal and after checking the test mode settings I saw that it said "Radio Off". I'm unable to turn on. Phone was not dropped or submerged.
Seems like a factory defect based on the number of posts I've seen with this exact same issue.
maahier
HI there. I am having the exact same issue. Did you manage to figure out how to solve the problem. Please let me know, I'm getting desperate to fix my phone.
Mjmdroid
Nope, I end up taking it to phone house and added more money for Samsung Galaxy s6
ownspy
You need to rehot or reball and finally change the baseband ic. I had the same problem and solved by rehoting the ic.
