Should I update to Lollipop?
aarohi
My mobile is sony xperia Z1 not compact. only Z1. i have heard from my friends that after updating the mobile gets switched off automatically and also unable to answer the calls etc. since i purchased i dint update it is still 4.4.4 version please tell me what i can do. thank u
Uliwooly
@aarohi
no problem, if you experience poor battery life, just reinstall the update again.
7 REPLIES 7
Uliwooly
@aarohi
does it restart if you remove the SIM and SD cards?
aarohi
I dint update it still i m scared to update
Uliwooly
@aarohi
I didn't experienced that on my Z1
aarohi
Ok thanks then i will update my mobile
thanks
Uliwooly
@aarohi
Harry_z1
@aarohi
If you are happy with current version, and not looking for any particular features in Lollipop then my suggestion is dont update.
In lollipop, Sony has moved the Xloud feature in ClearAudio (or removed it).  For many people, this has reduced the speaker volume very much. I almost need it to full to get reasonable output. Sony do not acknowledge that there is a problem. Keep saying - reinstall.
You can search this forum and you will see many thread about - low speaker volume after lollipop update
Its not that everyone has problem, but I thought I will highlight the risk.
cas27
@Harry_z1 wrote:
@aarohi
Hello
I agree, the sound is still very "poor" and low.
If you give much importance to the volume sound (multimedia) do not update.
