i have xperia z when i verify the bootoader unlock statut i found : NO
the sim lock statut Network 0.
please if some one can help me to change the statut to : YES
With no other particular, accept my best regards and I hope your answer.
Thank you.
Solved! Go to Solution.
Sorry to say but if your bootloader is hard locked then this has been done by your network or is a country restriction and can not be undone
