Hi
I have just bought a Smartband and am waiting for it to be delivered.
However whilst waiting for delivery I have discovered from my research that it may only be compatible with Android 4.4.
My Z is running Andriod 4.3. Does this mean that:
1. the Smartband won't work until I get the 4.4 upgrade later this quarter, or
2. will I just have limited functionality (i.e. the compatible Lifelog app won't work but the other Bluetooth-based functions ( e.g. when a call or message comes in, the SmartBand gently vibrates on your wrist) will)?
Can anyone advise?
Solved! Go to Solution.
it seems that the smartband will work with other android versions, it make sense that since its a new product they just focus on their latest flagship, but don't dismay
That's correct
http://www.sonymobile.com/global-en/products/smartwear/smartband-swr10/specifications/#tabs
Requirements
this has not been answered .... so yes or no?
It should work as it requires 4.4.But contact xperia care to be sure:
http://www.sonymobile.com/global-en/support/contact-us/
