The on/off functions turn red amd estimated battery life shows drastic drop.
Hanee786
At times, estimated battery life seems to he very low amd it is shown in red. Also the on/off functions are red and not green. Why??
Tags (3)
profile.country.RO.title
_alexdon_
That estimated time is related to your usage pattern, it will estimate less when you discharge your phone faster in the days before.
alexdon
7 REPLIES 7
Uliwooly
@Hanee786
could you elaborate? screenshots will help
are you referring to
settings > power management > battery > graph ?
Hanee786
Screenshot_2015-12-11-12-08-02.pngScreenshot_2015-12-11-12-08-10.pngScreenshot_2015-12-11-15-47-17.pngScreenshot_2015-12-11-15-47-50.png
Hanee786
the 8 hrs was when stamina mode was off and the 1day+ was when stamina mode was on. then everything else is red
_alexdon_
Are you talking about the background color of the battery estimation text? I think that's default, looks the same on my Z2.
alexdon
Hanee786
The thing is, when it is red in colour, estimated battery life is like less than 1 day(stamina mode off) or 1 day and a few hours(stamina mode on), but if it is in green, estimated battery life is high(easily  2 days and above). That is why the red colour worries me. Any insights on why this colour change happens?
_alexdon_
alexdon
azzido
Enthusiast
On/Off button color depends on a theme that is currently used.
If want green then change the theme to green.
If want to use different wallpaper too = change only wallpaper after that and not entire theme Winking_Face
