Hello there. I really need your pro advice on what I should do to fix my Xperia z3 issue. I just got my Xperia z3 about 2 weeks ago and it was running good until now. The problem is I don't receive any strong signal like before, right now I don't received any signal at all and when I make a call a pop up message comes on it says 'to make a call you have to turn off the flight mode' but the flight mode is off. I rest and restarted my phone but nothing changed. so please can you help me.
Solved! Go to Solution.
Hi @frostyboy,
I'd suggest that you test your phone in safe mode first of all. If it still won't work then you should proceed with the software repair using PC Companion as suggested by Phy.
Glad to hear that, thanks for letting us know!
