Xperia Z1 Glued with the Cover supplied coming off
GYSrinivas
Hi ,
I have boought this mobile 15 days back and been using the cover supplied alongwith the Phony company. But the glue is coming off and the phone has the risk of falling off.. Please advise how this can be glued back. If possible, suggest the available glue from market which can be used for this purpose. I am in Delhi , india. Thanks
Mystic
if you use a double sided tape, it has to be very very strong in order for it to work in holding the phone. so unless you are able to get good quality tape here in india (Ive seen that you dont really get great tapes due to the increased ambient temperature) I wouldnt risk using just any double sided tape for this particular application.. you have a 42k phone at risk.
4 REPLIES 4
Mystic
Honestly. the Glue that is used isnt just glue. its more of an adhesive tape. The only suggestion i could give you is to wash it a bit with water (no soap) try to remove the dust stuck to it without major rubbing. Then let it dry and then restick it to a clean phone surface.
If this doesnt work id suggest getting another cover. The one that is supplied with the phone is actually really cheaply made and isnt the best cover to be used anyway. (It also has major issues while using the camera. It reflects the flash)
GYSrinivas
Thanks. I agree that this is not the best method to protect the phone. However having bought this i do not like to go for another cover at this point of time. The tape is no more adhesive. Do you suggest any double sided sticking tape to stick my phone for now.. thanks for your view..
Mystic
GYSrinivas
Thanks I agree with you. Shall go for another case. Any recommendation for this ? :-))
Srinivas
