Good day!
I'm Having a problem connecting my Phone (Xpeia Z1) to my PC through PC Companion (Wifi Connection). After some steps my phone gets stuck and wont continue on the last step. i even Left it overnight to give time to connect but i woke up and still its connecting. i have successfully paired up my Device on my Office PC. But i can't get it to work on my Home PC/Laptop. i Don't know if I'm having some problems on my PC or my Wifi Router. So i need some help from you guys, what do i need to check to get this thing to Work. If any on you have the Same Problem please Post it Here, or if you have any solutions please give me some advice.
I Was Stuck on this part of the Setup:
So There, as you can see, i have successfully Paired my Phone and my PC (ANDREWSTAR). But on this Part (Connecting) i got stucked. And it never Finished Connecting to my PC.
The Other Device Name (AKD-RSF) is my Office PC which i Connected my phone without Problems.
So there you go guys, i could connect it Through USB Connection but i don't want to always open the Micro USB Cover of my Phone because it might get loose and eventually the Water Proofing capability of the phone gets useless. That's why i want to get this thing working up. The other Workaround i find here is to use a 3rd Party app to Transfer Files wirelessly. But i don't want that. Because this thing should work and i think this is a safer method of transferring my files.
Thank You Guys!
Solved! Go to Solution.
Thanks, that really solved it!
