Xperia Z2 vertical lines/screen turns white.
RaidenMGR
Hello.
After LCD replacement the screen has some vertical lines and turns into white (you can still see everything) but has more white into it, and if i lock the device and wait 3-4 seconds and open it again the vertical lines disappear and the screen looks normal for a few seconds, but after it goes back to the white/vertical lines.
Is this a flex cable issue or a motherboard issue, does someone knows?
Thank you.
Lord_viridis
Could be either/or.
I assume you did the repair yourself? If not, contact the repair centre that did it.
Although the signs posted indicate a loose or shorted flex, I wouldn't recommend fixing it yourself and would always advise you to contact your Local support.
RaidenMGR
Yes and when i test both the previous broken digitizer LCD and the new one, the vertical lines are there, so its not an LCD issue.
I just want to be sure if its the motherboard or flex cable, because before replacing it, there were no vertical lines at all.
Thanks for your answer.
