Xperia Zl Camera issue
harimaru
Hi all,
   I have an issue with my phone camera, there is some dirt/dust on my camera lens, and its realy annoying, i cannot use my camera, as i used before, since i used it (used too) quite a lot, and on every picture clearly you can see that black dot, and its moore annoying when you take a full body picture, the dot seems larger. (i have this problem for 3 weeks now)
Sam
Legend
Legend
I would advise contacting your local Xperia Care team so that they may assist you in having your handset assessed by an authorised repair agent.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
Sam
Legend
Legend
