Now I have a Sony xperia Acro s and has a memory partition for the apps (this 1.97 gb) and the system giving me notifications for low memory. I have moved all the apps from device memory to internal storage. But some apps I cannot move it but still this problem not solved ! I found a info about device memory and it's says I can not extend this type of memory.
My question is: Z1 Compact have it any restriction about device memory? Because I want to change my Acro S for Z1 Compact.
Thank you!
PS: Sorry for my English, is not my native language.
Solved! Go to Solution.
Z1 compact does not have that kind of partitioning,there is only internal memory.
Z1 compact has about 12 GB of memory which you will be able to use.
Thank you for your answer. My Xperia Acro S have same internal memory (11.25 GB usable) but it's create an additional partition for the apps (1.97 GB) and this kept me to instal a define number of apps.
Thank you!
Anytime.
Actually,2 GB is the total amount and if you divide it with 1024^3 you get 1,86.From there,the OS is taking it's part and the rest is yours to use.
