Z2 update problem
Czaker18
Z2 update problem
Hello, I got a problem with updating to lollipop, my pc companion turns off my z2, next i must turn it off again when it's off **bleep**. Next when I must pin up usb to phone with pushed lowering button nothing is happening. I tried many times, i pushed other buttons but it's always the same.
Czaker18
i don't have any error, I can't get through preparing phone for update, there are five steps Face_with_stuck-out_Tongue I'll try with my laptop
Edit: No need help anymore, thanks guys for fast replying Slightly_smiling_Face
4 REPLIES 4
profile.country.US.title
Qatrium
If you're updating, the software will automatically power off your phone. You don't need to power it off.
If you're doing a software Phone Repair, you need to power off the phone yourself, may be wait a bit (like 30 sec) then press volume down and attach the USB cable while you're holding volume down and the mobile is still off.
Czaker18
It didn't helped, pc companion can't go to the next stage. :c
profile.country.RO.title
_alexdon_
Czaker18
