Z5 compact disconnects fron wi-fi after being idle for 5 or 10 minutes
Markon86
Z5 compact disconnects fron wi-fi after being idle for 5 or 10 minutes. I have nougat 7.1.1 and this symptom started only a week ago, never happened before. I put my phone down after using it normally on wifi. Ten minutes later I wake it and look at the lock screen and I see it disconnected from wifi and it's only on LTE.... Without having moved it from the wifi range.
Markon86
I think I found the problem. Found this setting here that i never knew existed. For whatever reason, it was set to "NEVER". Not sure if this was recently added or what... Still waiting to confirm this takes care of it:
Markon86
NeoBeum
Enthusiast
Yes and no...
If you still have problems add anything wifi to the battery optimisation whitelist... The numptys at google are numptys...
Markon86
That was it for me, I'm still a bit surprised that feature out of the blue enabled itself. Oh well....
