E-mount
profile.country.SE.title
imreh3
E-mount
I have a Sony a7r and then later I bought a Sony a7rIII. Now the mounts are a little different, the rIII is a lot tighter, so I strugle with lens changes. Anybody with the same problems? Solutions?
Kind regs: Imre H.
Marino.Manolo
Genius
That is impossible... O_o
IamNic
Hello @imreh3,
could it be that you dropped the old camera with the lens attached or applied any force so that the lens bayonett and camera bayonett bent/deformed in such a way that they still worked together but now the lens does't fit perfectly with the new camera anymore.
@Marino.Manolo
under the above mentioned circumstances it indeed can happen.
- Nic
imreh3
Well, I don´t think so, the mounts are different, I need two different adaptors as well....:-(
