GP-VPT2BT
Dillion1951
GP-VPT2BT
I have the above shooting grip and I am connecting it to my A7R iii but find there is no zoom function when I shoot in RAW. It will work on the hand control zoom button if I am in JPEG mode.
Any suggestions?
5 REPLIES 5
Pascale_F
Moderator
Hi Dillion1951
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi Dillion,
Have you made sure the camera is up to date?
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7rm3
Win_88
Dillion1951
Hi
Yes had checked that and I am on V 3.10.
But thanks for the suggestion
Dillion
Win_88
Specialist
Hi Dillion,
This is apparently a part of the design of the camera:
https://helpguide.sony.net/ilc/1710/v1/en/contents/TP0001653109.html?search=raw
Win_88
Dillion1951
That is great, at least I now know I am not going mad. Thanks for the reply
