hdr-cx130e shutter not shutting
threeputt
bought a hdr-cx130e from Argos in Jan, i have all of the details and registered the camera on My Sony which includes the serial number & date of purchase, but I cant find the original Argos receipt, will I have a problem getting a repair under warranty ? I presume its pointless trying to get a copy receipt from Argos ?
Basically the shutter that springs shut when opening & closing the viewfinder isnt working and its now shut half way, can hear it trying to open/close but failing, maybe theres a spring in there thats broken, either way its only 6 months old and not used that much but stopped working when i needed it most. is this a common problem ?
Mick2011
Hi threeputt, welcome to the Sony Forums :slight_smile:
I have no idea if this is a common problem, but you should be able to register the camera for a repair as normal, using the details on this sticky.
Hope it all works out.
Mick
Mick2011
Mick
