How to disable flash? - Sony a6000
t.romaniv
Hello.
Can anybody explain me of how to disable a flash in any of P/A/S/M modes?
My Sony a6000 camera says me that I can't disable flash in those modes. But, why?
Maybe I'm doing something wrong?
Thanks.
34 REPLIES 34
timojk
Hi
Currently I'm just using a black tape on front of the optical cable holes and let the internal flash fire even ext strobe is off.
Br. Timo
Continuous shootnig is also lost if flash enabled.
Any news from a fix fot this?
divespotchecker.de
see my little video on you tube
https://youtu.be/p3kNzb2jWfY
i solved the problem like this
br
divespotchecker.de
Sony A6000 with Meikon /Neewer dive housing. Flash problme. Can t turn off when flipped out . My solution An alle A6000 User. Habe durch Zufall herausgefunden das die Blitzsteuerung der Sony A6000 per Magnetschalter arbeitet. D.h.man kann relativ einfach das Problem des nicht über das Menü ...
erpenma
Its the same with the a350 a nuisance when doing bird photography either the noise of the flash popping up or the flash itself scares them away before the shutter fires .
chargingarc
This appears to still be a problem in 2020.
A7RIII
Combined with the hot shoe detection flash 'preview' mode on the display and some other Sony weirdness ...
Regretting buying into Sony now 😞
