what is the difference between Sony HDR-AX2000e and HDR-AX2000
finnsims511
blaireau_photo
Hello finnsims511 - welcome to the Sony Forums.
The 'e' on the end of the model number specifies that it has been released for the European market and as such it is designed to record video in a European format i.e. PAL.
You can find the full specification at:
http://www.sony.co.uk/product/cam-high-definition-on-memory-stick/hdr-ax2000e
Simon
blaireau_photo
Simon
