Memory Card File Rescue Software
aga2k3
I cannot seem to download the software I fill in the details from my memory card press download and the next page just comes up with "This session is invalidated. Please restart your operation from the beginning."
any help please or alternate download site thanks
Thalamus.
Champion
Hi aga2K3,
I do not have a Sony branded SD card to hand so can't check if the download works..
Have you checked that you are entering the correct serial number & downloading code.:smileyconfused:
Don't know the serial number or downloading code?
Thalamus.
Champion
Hi aga2K3,
aga2k3
just tried again and its fine now guess it was just a broken link thanks
Thalamus.
Champion
Excellent, thanks for posting back..:smileyclap:
