Help with a vintage LBT - D209 HIFI stack
Mikeanddawn
Hello,
 I have a LBT-D209 stack, but there is no record player.  I would like to buy one that would fit on top of the stack.  On the back of the stack there is a power source which states it is only for the PS-LX52P.
Does this mean it is the only record player I can have?  The other query is that the stack measures 35cm x 29.5cm, but I believe the LX52P is bigger so won’t sit on the stack, or am I wrong!
Thanks for your help.
Mike
Vanilla_
Hi Mikeanddawn,
I've tried to check the User manual for your model to see if I can get these answers for you, But the support information is no longer available on the Sony website. I guess that's because the system is a bit old now. I can only suggest that you check with Sony engineers to see if they can offer more help: https://locator.sony/en_GB/servicecenters/?zoom=5&latitude=54.29088&longitude=-2.37305
Regards,
Vanilla_
Sean_Mc
Moderator
Hi Mike,
I'll try and find out for you and will update the thread when I have an answer.  Perhaps another member of the community may be able to help in the meantime.
Best wishes,
Sean Mc
Vanilla_
Hi Mikeanddawn,
Regards,
Vanilla_
Mikeanddawn
Thanks Vanilla,
l am going to risk buying the turntable and connecting it to the stack.  There are enough of them on eBay and they are cheap so I won’t lose too much if there is a problem.
kind regards,
Mike
