I have tried the box on two TV's and a monitor and the box will show the Sony boot screen and then as it would normally go onto to the next stage in the android loading it just gos blank and all displays state cable disconnected.
This sucks. Any one got any ideas? Can you do a factory reset withought a gui like a hard factory reset?
Please help or I am sending this unit back and sticking with my revue.
I rang Sony support about why the box would not work......they do not have an answer!!!!!!...great support!!!!!
I think the answer to the problem is HDCP! Th ePioneer tv that I have has had a connection problem that means the tv does not allow connection.
If you Goggle HDCP Pioneer tv all will be revealed.
The result is that video is not displayed ie a blank screen.
First discovered with Sky tv boxes.
