I have a KDL-40NX723 TV which has built in wifi connection with
a BDP-S480 Blue-ray player which doesn't.
Question is can I link teh BD player to the network via a wired connection
through the TV ?
Solved! Go to Solution.
your player has an ethernet port on the rear panel just connect using an ethernet cable to your router.
