BDP-S570 Problem with 3D
davenport51
Player has been working fine for 3D films but now shows message saying the 'player or display is not 3D compatible'. I have not changed or moved anything (both payer and TV are Sony and the 3D has been working fine until this weekend). 3D from Sky box is still working so I guess the problem is not with the display side of things. I have pulled out and re-fillted all connections and made sure that latest software is installed but still no joy. Has anyone else had this problem and found an easy fix or is it a case for repair (grrrr only just out of guarantee!).
Bernie
Catmambo
Are you running the latest firmware on the device? There have been a bunch of updates for his device, so it's well worth checking as some of these were definitely related to 3D.
Instructions in the Smart TV FAQ sticky on the main page of the TV forum.
