BDP-S6200 TRUEHD Passthrough DLNA
zaim7890
I'm having issue's getting TRUEHD Audio passthrough via HDMI to my AV Receiver. Works fine via Blu-ray discs but not via DLNA. I didn't have this issue with my previous players (4200/490)
My AV Receiver shows LPCM instead of TRUEHD.
Anyone know what is causing this?
5 REPLIES 5
MK_Slinky
Firstly it would be helpful to know what AV Receiver you're using, we can try and help once we have this information.
If you have already found a solution perhaps sharing it with this community would help others with the same question.
The User Manual is your friend..., seek forth and ye shall find answers. Can't find any? Join the club, we have all the answers here, occasionally they're even right! :wink: Dr.Slinky McVelvet - Inventor of the word 'Mellifluous' - 30.12.14
zaim7890
Hi, It's the Sony STR-DH820
MK_Slinky
Hi Zaim,
Sorry for so many questions but can you be more specific about what you are trying to do exactly?
Are you trying to stream audio from another device, i.e. PC, Laptop?
If so what software are you using? iTunes, WMP or some other programme?
Hi there
Try setting "BD Audio Mix Setting" to OFF and see if that makes any difference?
PS: Editted
MK_Slinky
Thanks for stepping in here Quinnicus, I'm not familiar with these products.
:wink:
