HT CT60BT try to pair with my tv not in list
sc00terx
i wanted to use  one remote  but my tv does not have this  in its   list even thoe  i got this as part of my tv  why would you  do this  am lost for words  so far from sony  😞 sad face
Hi there
Pairing to TV:
You cannot 'pair' the soundbar via bluetooth to the TV.  The TV will only accept Bluetooth mice.  The bluetooth on the soundbar is to connect your phone or other device to it.  You will need to connect the optical cable (provided) from the TV to the soundbar.
See the following thread for a little more info:
http://community.sony.co.uk/t5/televisions/bravia-42w815b-not-picking-up-bluetooth-devices/td-p/1647...
Single Remote Control:
Unfortunately you are stuck with using the small remote that comes with the soundbar.  Bravia Sync will only work with connections via HDMI (ie Control for HDMI).  This soundbar does not support HDMI connections.
http://community.sony.co.uk/t5/televisions/kdl-32w653a-to-ht-ct60-sync/td-p/1644039
Hope that helps.
Hi there
Pairing to TV:
Hope that helps.
