Assistance needed
LIZMACD
Assistance needed
WHen access Sony entertainment network cannot access videos. When press apps a continued message of "a refresh of Internet content is needed". Has only recently happened. Cannot access any channels on Sony entertainment network. Please can you help?
Hi there
Not knowing your exact model number, however this should work for most tv's I believe.
http://www.sony-asia.com/microsite/bravia_i-manuals/FY12/HX753/GA/c_gset_europeall_co_facset.html
Cheers.
Hi there
Firstly, ensure that your firmware is upto date for your model of tv.
Secondly perform a factory reset. Before you do, make a note of any custom tv settings that you may have changed (like picture settings) as these will be reset.
Hope that helps.
LIZMACD
HI there
THank you. How do you do a factory reset?
Hi there
Cheers.
