Bravia KDL42W829 - Start-Up Logo Gone
MichaelTUK
I have the Sony Bravia KDL42W829 The "SONY" start-up logo when I turn the TV on is no longer there. I have checked the settings and it is set to "On", I have turned the TV off at the mains for 5 minutes and back on again and I have done a factory reset. All that and the start-up logo still does not appear. Any solutions?
7 REPLIES 7
Hi there
I assume you've turned it on via these instructions : HERE ?
Other than the startup logo - does the TV work as expected?  If so, I personally wouldnt worry about it too much.
MichaelTUK
Yes I have tried that. The TV works as expected but I do not understand why the start-up logo has gone.
This happened after the latest firmware update.
Can you investigate?
MichaelTUK
Is the issue related to the recent software update?
ehasanov
Hi
Same problem here with KDL42W828B. But as I remember it worked normally after firmware update for some time.
Today I notice that I don't have startup logo with settings ON.
Edin
hcr_hassen
Does it matter?
Maybe Sony decided it was tacky and it was removed. :slight_smile:
What... Are you saying that the Sony Logo is tacky? :wink:
LOL
hcr_hassen
No, it's actually OK. But to show it on startup is. :slight_smile:
