DOUBLE IMAGE PROBLEM ON BRAVIA KDL-40NX723
TRUFFLES2012
HI, MY BRAVIA MODEL KDL-40NX723, KUST 15 MONTHS OLD HAS STARTED DISPLAYING A DOUBLE IMAGE PATTERN AT THE TOP OF THE TV SCREEN...Grr....HAS ANYONE EXPEREINCED THIS FAULT, IS THERE A FIX / UPGRADE..?..ANY ADVISE appreciated before i call support, AS THE TV HAS A 5 YR WARRANTY..MANY THANKS, JAMES....:smileyconfused:
Hi there
I have the same TV. I have not got this fault, nor heard about it. My advice is call in the warranty.
Cheers.
Hi there
Cheers.
