KDL-42W655A MKV
LukeHli
KDL-42W655A MKV
I apologize in advance for my bad English. I have a problem with my TV, my TV does not want to play any MKV files, we can solve it somehow? Thank you in advance for your answer.
Hi there
First thing to do it to run the problem file/s using a program called Media Info : HERE
Compare the codecs used in the summary report, to the supported codecs list : HERE
If they do not match up, you will need to re-encode the file/s using a supported codec.  A suggested program is Handbrake : HERE
Hope that helps
Hi there
Hope that helps
