KDL37W5500 Optical Audio and Update
sjjhr67
Dear all, I have an old but perfectly working KDL37, and a number of questions:
1: how do I set it so it defaults to HDMI2 at start up? It gets confused whether my Virgin box is turned on or not
2: when testing the internet connection, it switches off automatically so I can't tell if it's connected
3: can I updated it via the internet?
4: optical audio out doesn't seem to work when powering a Devialet Dialog and 2 phantom speakers
Any answers gratefully accepted thank you
EdwinaU
Moderator
Welcome to the community.
You'll find the manuals and help guide for your TV here. That should hopefully help with your questions.
Best wishes,
EdwinaU
