Netflix on kdl26ex320
clecky
Can i stream netflix on this model? I cant see icon, or do i have to subscribe first. I have lovefilm so would hope this model would also support netflix?
Hi there
In a short answer, No your TV is not compatible for Netflix as its pre-2012.  See the Netflix FAQ : Here
If you need/want Netflix, you could always add a Sony Blu-ray player such as the BDP-S1100, which retails for approx £60
Hi there
clecky
Thanks. How annoying!
