program information text too small
s.lowndes
Is there a way of increasing the size of the text on the program information on a kdl24w605a.
I understand that the larger the screen the larger the text but on the smaller screens you need a magnifying glass to read it.
Hi there
The following thread should explain things:
http://community.sony.co.uk/t5/Televisions/Enlarge-subtitles-on-bravia-kdlex650/td-p/644592
s.lowndes
Thanks for replying so quickly. But it wasn't sub titles I was meaning, it was the program information text when pressed the i+ button. Or does the same apply to this too?
Many thanks
Simon
HI there
Sorry about that, I took it as subtitles.  Unfortunately the answer is basically the same though.  It is fixed and cannot be changed.  However I think this time it is controlled by Sony - but is unlikely to change it.
Bigger TV is what you require unfortunately.
