Sat program KDL-46W905A
profile.country.DK.title
jetkeep
Hi On my KDL-46W905A change sat chanels on program plus or minus
should it not show the chanel in the small screen?
When i change to a new program either plus or minus in the list
the small screen is black shows nothing, but when i press ok
the chanel is shown full screen, then i must press program to get list again?
Hope you understand it would be much better when trying to find a program
i want to see if i could see this on the small screen first.
jetkeep
Hi thanks for your reply,
i have found a solution for this
when in chanel list press options
and the last one in the options list
auto program was off has to on.
Hi
When I change to the Sat channels, and press the P+ and P- buttons on the remote control, I get a preview screen - however it is a little slow to 'connect' and show the channel (approx 3-5 seconds ish)  So, it does work for me (KDL-42W807A).
Are you sure that its not a simple case of it being slow?
Bear in mind that the Sat channels are extra and that there is no real EPG guide (need to be Freesat for that).
jetkeep
