USB recording - add pre-time and post-time
profile.country.sk_SK.title
slamka33
USB recording on Bravia internet television works great, but, there is a small disadvantage which should be added via firmware.
Recording is only possible via
a) EPR digital program - it will record between exact time of the selected program
b) manual selected times - it will record between selected times.
Unfortunately, most of television in EU does not start and finish program exactly at the time as stated in EPR, so recorded program via a) is cutted at the end (because most of televisions are starting program later).
It will be great if is possible to set some pre-time and post-time which will be added for recording via a).
It means if I select pre-time 5min and post-time 30min, recording will start 5min before time stated in EPR and finish 30min after the ending time in EPR.
Is it please possible??????
Tags (3)
dseabrooke
Just bringing this I solved issue into 2013.
Wake up Sony and monitor your forums!!!!!
Message was edited by: dseabrooke
Unsolved issue
