Wall Mount for KDL-55W905
TimWoo
We're hoping to buy a 55" W9 very soon, but are unable to find information on the wall mount options. I assume that there are standard VESA mounting points, but none of the documentation I can find online confirms this. - The QuickStart Guide shows how to attatch the stand, and the iManual / reference seems only for operational features.
Is there a recommended wall mount for this TV?
Where can I find information on the horizontal/vertical spacing of the mount points?
Thanks in advance,
TimWoo :slight_smile:
profile.country.it_IT.title
jan2011
Enthusiast
The only document that I found is this:
http://www.docs.sony.com/release/KDL55W900A_cutsheet.pdf
KDL-55W900A is the “corresponding” US model of KDL-55W905A.
If you see (upper right angle) there’re all dimensions (even “Vesa Hole Pitch”) for all over the world models of this TV. All have the same value!!!
The KDL-55W900A (US model) have
Regulation and Standards compliance:
“VESA® Hole Spacing Compatible is Vesa -->  Yes"
http://www.docs.sony.com/release/SPECS/KDL55W900A_mksp.pdf
Take a look even here (original Sony accessories):
http://store.sony.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=...
Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free.   (N.K.)
4 REPLIES 4
jan2011
Enthusiast
TimWoo
Thanks Jan, molto grazie!
It didn't occur to me that the UK Sony website would have different documentation for the same model in the US. :dizzy:
jan2011
Enthusiast
Di niente!!!  :wink:
I don’t know if all other specifications are the same, but the “BOX” is identical!!!
Have a nice weekend!!! :slight_smile:
Ciao!!!
Marino.Manolo
Genius
Montaggio a parete standard VESA 30.0x30.0 cm > Wall Mount VESA 30.0x30.0 cm
http://infosony.sony.it/contents/instance1/files/document/2379KDLW905AB.pdf
