Blue tooth headset
Sonyfreak
Blue tooth headset
Sony vaio 297 XP with built in Blue tooth
How can I connect a blue tooth headset with mic ?
How can i use it in combination with skype ?
The headset is discoverd and paired within the standard software. But thats all
rich912
The built in Bluetooth uses XP drivers and unfortunately they don¿t support headsets.
The Widcomm drivers do but I am almost certain that you cannot use these drivers with your `built in¿. You will need to use a BT dongle with Widcomm drivers:smileysad:
Go n-éirí an bóthar leat
ZeroBk
It is possible, I have done it myself, but it need some tampering.
Send me an IM on skype (user: nilback) and I'll send you some files and instructions.
There's also a lot of info on how to do it in the hardware section of the Skype forum, but specific for Vaios.
