BX397XP Vista Driver
Giovanni26
I try to install catalyst driver for vista on my bx397xp but don't work!!
I try with sony xp driver but the system crash.
have you find a solution?
Giovanni
Giovanni26
Hi all,
I have find the solution :wink:
Now all works, Aero, Catalyst control Center exc.
For the screen (read my other post; the screen are not good like bx297xp) i think to know the solution.
If is good I tell you here.
(the problem are for all new screen with resolution 1900x1200)
